跳转到主内容
这是Google公司生产的第一款智能手机,Pixel XL(型号:G-2PW2100)发布于2016年10月20日。其配备5.5英寸AMOLED显示屏,3450mAh电池和32GB或128GB可选存储空间。
70 个问题 查看全部
Pixel XL WON'T Charge/Connect to PC
I decided to do Teardown & Reassembly  of my Perfectly working (OLD & beat up) Pixel XL.  After Reassembly  everything WORKS except it WON'T Charge or Connect to PC. It appears that the USB Port at the bottom is DEAD, Anything connected to it ( AC charger or USB to computer) WON’T do anything to the phone.when i connect it to computer i get No Notifications on the phone.  Replacing  the bottom charge Connector board  did NOT help me. What went WRONG any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Thanks for your quick Reply.
NO changing to a known Working Ribbon cable DIDN’T fix my problem. and there is No damage to any of the 4 Connectors (2 on the Ribbon cable and One each on the Dock Connector & Logic Board). Since the ribbon is the only one that connects two areas of the phone, so something went bad during reconnecting.the ribbon cable is BARELY long enough to be able to position right on top of the connector once we connect one side of it. So i think one end of the connector didn’t seat Perfectly and Shorted/burned the USB Controller (or whatever) thats on the logic board side) because changing the dock connector board is NOT fixing the phone. So whatever is causing this issue is on the Main board. I think its history. I will update the forum if i find a Working Solution. Hoping for the Best.
完成的
Mines intermittent ,I've taken it apart to replace the port and it worked for about 10 mins and stopped. i've also let it charge without the mid-frame in and it works perfectly but as soon as I put the mid-frame in it either doesn't work at all or for about 10 minutes.
完成的
This is easy to solve. When you press the mid frame into position it is causing some unnecessary contact giving you the problem. most likely the dock board is not seated correctly. If you think the dock board is seated correctly then cover the underside of the mid frame that is directly above the whole of dock board with some thin tape/paper and see what happens.
完成的
添加一条评论
1个答案
最有帮助的答案
Maybe perhaps the ribbon cable connecting from the dock to the logic board has gone bad? Have you inspected connector on both sides for any signs of physical damage?
这个答案有帮助吗?
得分 1
2条评论:
Did the new cable work? I'm having the same issue.
完成的
HAPPY to report a second NEW cable WORKED. Don’t know what went wrong with my Original cable or the first NEW replacement. So it was the cable that went bad or NOT seated Properly( Hard to believe cause i took all the proper CARE.).
Thanks for all the help
完成的
添加一条评论
添加你的答案
Google USER 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 142
