跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
230 个问题 查看全部
Why did the screen go black even though it was still working
The screen went black but the phone was still working. Eventually it stopped working altogether
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Your screen probably went bad. Was it doing anything suspicious before this?
完成的
添加一条评论
2个回答
Probably a display issue. If you replace the display you should be fine?
这个答案有帮助吗?
得分 0
添加一条评论
Before replacing the display (especially if it doesn’t have any physical damage), try a button combination to reset the phone. S6 is notorious for becoming unresponsive for no reason (in my experience anyway)...
Power + home + volume down will take you to download mode with an option to reboot the phone. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelly 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 31
