跳转到主内容
The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
52 个问题 查看全部
Stuck! Car still won’t turn over after new fuel pump and power checks
Hi. I have a 2000 Honda Civic. One day I drove the car about 140 miles then get home fine and went to turn on car about an hour later and it wouldn’t turn over. Used starter fluid and car wanted to start when sprayed. Replaced the fuel pump with a new car quest pump but still didn’t work. Checked the grounds around the engine. Checked power to pump relay which was good and it clicks. Checked power to the fuel pump which was good. Replaced fuses for ignition coil and a few others. Still same thing it doesn’t want to turn over. It cranks but nothing more! Any help I’m stuck??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Combustion engine need air, fuel and a spark to turn over. If using starter fluid almost gets the engine to run then it seems a problem with fuel flow. Since you replaced the fuel pump then check the fuel filter as well as the fuel line for obstructions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeremy Levine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 211
