跳转到主内容
加入维修社区 - 创建账户
The third iteration of the 10.1 inch Galaxy Tab tablet.
Galaxy Tab still no working after battery & charging port replacement.
Hi all,
I have a tab 3 that went flat a few weeks ago. I tried to charge it and nothing happened.
I did a bit of searching, tried multiple button combinations but nothing worked. I replaced the charging port first, no change. I then replaced the battery and still it doesn't show any signs of life.
I used a multimeter and confirmed that the charging port is working, I am also using the Samsung travel charger but with a generic cable.
Just wondering if anyone has any further suggestions? Thank you very much.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Would appreciate any advice/suggestions before I throw it away, cheers
完成的
添加一条评论
1个答案
I would try using the original wall charger and charging cable for this tablet. I have noticed that they seem to be very particular about what charger is being used. It would help if you had a USB ammeter you could connect to the wall charger so you can see what amperage is being read.
这个答案有帮助吗?
得分 0
1条评论:
For this model in particular a 2A charger and a decent / good microUSB cable should work fine on this tablet.
完成的
添加一条评论
添加你的答案
Owen J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 368
