跳转到主内容
修复你的物品
维修的权力
商店
型号A1367,闪存容量:8、16、32及64GB
1310 个问题 查看全部
iPod will not charge and is not recognized by Itunes
i have an ipod touch 4th gen, and it does not charge.  it is strange to me though because it plugs into speakers through the charging port and works fine, but it does not stay on.  then when i try to charge it, it shows the "its dead" charging symbol, so it is charging. but then when it turns back on, it does not continue charging
i have also used several different cables in case it was a cable issue; i even bought a new one. but that did not help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
2个回答
Have you checked the 30-pin connector (where you plug the cable)? Make sure it’s clean and there are no broken or bent pins.
这个答案有帮助吗?
得分 0
添加一条评论
You need to replace it.iPod Touch 4th Generation 30 Pin Dock Connector Replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Randi 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 29
