跳转到主内容
The Cadillac DeVille was originally a trim level and later a separate model produced by Cadillac. The first car to bear the name was the 1949 Coupe de Ville, a prestige trim level of the Series 62 luxury coupe.
30 个问题 查看全部
How do I get my driver side window to go back up?
My driver side window will go down for it won’t go back up on my 94 Cadillac Deville. Automatic window.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@bmcgill could be the switch as well as the window regulator. You could try to jump the regulator once you remove the door panel etc. to see if it moves up. If so it is most likely the switch and vice versa.
Take a look on here for more info
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 51
