跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 个问题 查看全部
MacBook Pro non start no light on charger
Had logic board replaced, now completely dead. Charger does not light up. Charger, & power source good. How can I test to see if this is a battery issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
What color is the MagSafe adapter? Amber or Green.
完成的
You had the logic board replaced or you did it yourself?
完成的
Have you tried an SMC reset? https://support.apple.com/en-us/HT201295
完成的
No light on charger
I had logic board replaced by someone else
I have tried SMC reset as well.
完成的
添加一条评论
2个答案
最有帮助的答案
If you have no light on the MagSafe you’ll need to check it as it’s likely damaged Apple Portables: Troubleshooting MagSafe adapters and make sure you are using a real MagSafe charger OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth.
Inspect the systems MagSafe connector make sure the contacts or clean and shiny if not you’ll need to replace the MacBook Pro 15" Retina (Late 2013-Mid 2015) MagSafe 2 DC-In Board follow this guide MacBook Pro 15" Retina Display Late 2013 MagSafe DC-In Board Replacement
MacBook Pro 15" Retina (Late 2013-Mid 2015) MagSafe 2 DC-In Board图片
产品
$29.99
这个答案有帮助吗?
得分 2
添加一条评论
I think that If someone did replace your logic board you need to check with him first to see what’s the problem because if you try to make your stuff and was the logic board installation there is not way to prove that was a bad logic board installation or the logic board have fail.
Regards
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jim McDermott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 70
