跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
after open the screen the flat of the touch id not working
when I open the screen just to change the battery the flat screen of the touch id does not work, aesthetically it seems not to have suffered damage but the strange thing is that it does not always happen even if I open the screen the same way, it happens also to someone else? I repeat that the flat screen is damaged NOT the home button.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It’s usually a tear on the screen cable for touch ID and 3D touch (Not visible unless you remove the metal back plate that is screwed behind the screen. Happens a lot if you let the cable pull while plugged in.
这个答案有帮助吗?
得分 0
1条评论:
but it seems to me to open the screen in the same way .. so how should I do to prevent it from breaking?
完成的
添加一条评论
do you mean this
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mario rossi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 46
