跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
153 个问题 查看全部
Cranking but won't start
My car started running hot. Heater wouldn'twork either. My boyfriend replaced the water pump and the 2 themostats. He drove it down the road it didn't get hot. He shut it off and went to start it back. Wouldn't start only crank. So he replaced the crank senor wasn't it. Checked the plugs. It's getting fire. The fuel pump is coming on. He also took the air mass senor out still wouldn't start. I took it to mechanic he's had it for a week. He still don't know either. But keeps telling me he'll have it fixed the next day.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
the fuel pump coming on does not put fuel in the engine. The injectors are responsible for that. You need fuel, air and spark. Assuming the air filter isn’t totally blocked which would cause it to flood, and the spark is good, then the injectors are not working. Could be a timing sensor, blocked injectors or computer.
这个答案有帮助吗?
得分 1
1条评论:
Check your security system
完成的
添加一条评论
have your mechanic check your heater core..
Plugged heater core.
Update (03/07/2019)
or a faulty thermost that is sticking.. or installed backwards..
has your mechanic pressure tested your cooling system? and performed a leak down test?
这个答案有帮助吗?
得分 0
添加一条评论
Have u tried the main
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Heather 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,586
