跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
235 个问题 查看全部
iPhone XS max "no service" after water damage.
Hey, i recently brought an iPhone XS max and all of a sudden it stopped getting service, I don’t remember ever getting it wet but the water indicator has turned red. Everything is working perfectly and it even reads the sim card and what carrier it is etc but under settings<general<about it says network not available and when i tap on that is says “Phone not allowed” i was wondering if there is a certain part that would of shorted that is causing this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个回答
已选择的解决方案
With water damage, you have to decontaminate the entire logic board before doing anything else, otherwise there will be latent issues down the road even if you do fix it.
The iPhone X has a sandwiched logic board which makes it virtually impossible for a proper DIY decontamination but you can still follow most of these guidelines.
The proper way treat a wet phone is to do the following:
  • Open your phone and remove the logic board
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, pretty much all of the “logic” is hidden inside the logic board sandwich. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
A professional repair shop that does water damage repair may be able to recover your data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no data/no fee policy so you don't have to spend money to find out if the data is recoverable or not.
这个答案有帮助吗?
得分 3
添加一条评论
Hi Adam did you buy the phone new or used. If it was used it may have been blacklisted. In the dial screen type in *#06# to see if it shows the imei. If it does post the imei on here and I will check for
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
adam smith 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 15
总计 2,490
