跳转到主内容
A 5.5 inch smartphone from Alcatel announced on October 2015.
19 个问题 查看全部
My Alcatel One won't charge.
My Alcatel won’t charge. Kindly help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
6条评论
My Alcatel phone won't charge
=== Update (09/21/2019) ===
My Alcatel phone won't charge properly
完成的
My alcatel phone has the charging logo on but its not charging still
完成的
it showing a charge sign but it not working
完成的
My Alcatel won't charge. It says charge voltage over limit
完成的
Did you check the charging port? Try to see if there is something blocking the charger from fully entering.
完成的
显示更多的1条评论
添加一条评论
5个答案
最有帮助的答案
Try each of these steps if your phone has charging issues.
Verify that your phone, charging port, and battery contacts are not damaged.
Carefully inspect your phone to be sure it's not overheating, swollen or damaged.
Carefully inspect your phone's charging port and remove any debris.
Remove the battery.
Carefully clean and inspect the gold contacts on both the battery and on your phone.
Caution: If your phone is damaged, do not complete the remaining steps in this guide.
Verify that your ALCATEL can power on.
Turn your phone on.
If your ALCATEL does not turn on,
Verify that your charger is working.
Connect your phone to your charger and see if the charging icon displays.
Note: You risk severe damage to your phone if the charger isn't the same voltage, amps, and plug type as your original charger.
Verify that your ALCATEL is running the most recent software.
There may be a software update that improves battery life on your phone. Check for software updates.
Safely remove your SD card.
Turn your phone off.
Remove the battery.
Remove the SD card.
Reinsert the battery.
Turn your phone back on.
Perform a soft reset.
A soft reset restarts your phone and does not erase any of your content or data.
Remove the battery. After 30 seconds, reinsert the battery.
这个答案有帮助吗?
得分 3
添加一条评论
There could possibly be a problem with your charging port, so you should take a look at that and it might fix your problem.
这个答案有帮助吗?
得分 1
添加一条评论
Alcatel REVVL 4 is not charging only five months new. Can not get through to Alcatel no one answers.
这个答案有帮助吗?
得分 1
添加一条评论
My Alcatel one won't charge and would like to know how I could fix it
这个答案有帮助吗?
得分 1
添加一条评论
My Alcatel phone won't charge. I've noticed that others I know who have the same phone are also having this problem so it's gotta be a software issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephen 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 82
总计 15,463
