跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
touch id not working after screen replacement
so I replaced the cracked screen of my iPhone 7.
the touch id and home button worked for a little bit of time.
after a while, the phone just turned black, showed a loading icon and turned off.
I turned the phone back on but the touch id and home button stopped working.
i checked connections, tears, and there was no issue. I put the button back on to my old screen and it worked.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Try a different screen. Often when I have one that does that, it’s just the screen. Each has a flex for that button. Some are cheaper than others. Sounds like all you need is a better screen!
这个答案有帮助吗?
得分 1
添加一条评论
If you replace your home button by somewhere other that apple touch ID wont work. So I am assuming that when you replaced the screen you also replaced the home button. The reason is because the home button needs to be paired with the motherboard witch only apple has the ability to do that.
这个答案有帮助吗?
得分 0
1条评论:
No, I did not replace the home button as well. just the screen
完成的
添加一条评论
添加你的答案
pritham 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
