Very Loud In Spin Cycle
The washing machine works great, but is super loud during spin cycle….can hear it on other side of house with the door closed to laundry room.
Any recommendations? Thank you.
Matt Gibson
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.
这个答案有帮助吗?
It’s the bearing that’s making the noise not the belt. It’s common in these washers, need to either order a kit and replace it yourself or pay someone to do it.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 88
总计 7,562
2条评论
What type of noise is it producing?
由 mayer 完成的
The actual spinning. It’s not a grind noise, or a screech, it’s not overloaded.
由 Matt Gibson 完成的
