Why aren't my tach and speedometer working?
I just bought a 92 4runner that needs a fair bit of TLC. It runs well, but there are a few things that I'm leary of. 1st, I need to know how I can fix my speedometer and tachometer (note, only those two dont work. The rest of my gauges work fine).
2nd, (bonus question), how would I go about reconnecting my ebrake cable?
According to the previous owner, when he had the engine swapped (it was the 2.9, but he swapped it for the 3.4), the mechanic simply didnt reconnect the sensors for the tach/speedo. Additionally, by what he said, the ebrake was disconnected for some work he did himself, he just never got around to putting the cable back in.
Just in case it makes a difference, it's a 5 speed manual, 4x4. Anything anyone needs to know, just ask.
3条评论
Have you reconnected the sensors?
由 TheYootz Media Group 完成的
I suppose I should've clarified: I was more so asking for info on their location. I've looked and cant find them.
由 Synth Wolfe 完成的
The first thing you need to do is make sure that the fuel lines are disconnected and put the cap back on. Turn your vehicle off and then try again. If you still have no luck restarting your engine and turn your car off again. This should reset the fuel pump allowing the fuel lines to reattach and start working again.
由 Whaskince 完成的
