Turn signal/parking light problems
I replaced the front right turn signal light even though the parking light worked now the parking light works but the turn signal does not
Hi,
According to the owner manual for the vehicle the parking light (do you mean the side marker next to the turn signal?) uses the same value / type of bulb as the turn signal.
Swap the bulb over from the side marker light connector to the turn signal connector and check if the turn signal works.
(click on images to enlarge for better viewing
这个答案有帮助吗?
Wrong bulb, loose bulb/socket, socket not fully installed, broken wire, the problem is something you did or touched or broke. Visual inspection is next, then swap bulbs around then test for power and grounds if you have a multimeter. Additional electronic troubleshooting will be needed if the simple stuff does not bring up a solution.
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 217
4条评论
Does anyone know what the issue is
由 Autom Kitchens 完成的
I don't know what the issue is. The socket is lose is all I can guess.
Hi,
Was the turn signal light faulty before the change?
Did you check that the turn signal bulb is OK?
Have you visually checked the filament in the bulb to see if it is still OK?
由 jayeff 完成的
I'm not sure I left it at auto zone
