跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
Unable to open up phone for battery replacement
I’ve reheated the iOpener many times and re-applied many times (timing to make sure I’m a little over the 2 minutes suggested). I also used a heatgun until the back was too hot to keep holding my hand on it (and then of course stopped at that point).
No matter what I do with the suction cup (I bought the full official repair kit) and spudger+picks, I’m not getting even a little separation.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Make sure your suction cup is right under the camera to the right and has a good grip. Start pulling and try to get your spudger in between. If you aren’t able to do it maybe ask someone else to do it.
这个答案有帮助吗?
得分 1
6条评论:
Ok thanks, Ahron. I heated the left side and put the suction cup on the left side. Which side should I heat then if the suction cup is on the right?
完成的
I don't completely understand you but did you open the left side? If the suction cup is on the right then heat the right side up.
完成的
I heated the left side and put suction cup on the left side. There was no movement.
完成的
Sound odd maybe heat it more or use the spudger and try to stick it in as your pulling.
完成的
It seemed odd. I'm very particular about following directions/recipes. Did a lot of sticking and pulling at the same time to minimize how much more heat would be needed.
I'll try another side and hope it gives me the "in" so I can start cutting through the glue as I go around. Just can't cut without having at least a bit of a gap.
完成的
显示更多的1条评论
添加一条评论
Blast lots of heat on the glass with a heat gun for several minutes. Pull up from the bottom with a suction cu and get a pick under there. Keep blowing hot air as you keep prying the glass off. It’ll come off like butter
这个答案有帮助吗?
得分 1
2条评论:
Ok, thanks, Daniel. I started on the left side since that's what I was told by the online guide. Looks like I should try the bottom (or right side as suggested above) instead.
Would really, really like to see it come off like butter.
完成的
It will. I fix the Samsung’s all the time. You need lots of heat to lift the glass
完成的
添加一条评论
添加你的答案
Jonathan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 241
