跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Weird grey lines on starting screen, in system blue lines.
Hi there, can anyone help me ? I have here friend’s iphone 6 - i replaced him screen around 6 months ago and yesterday he call me that on screen start appearing weird blue lines and when he turn off and then turn on a phone he have weird grey rectangles on the side’s of apple logo - here you have screen https://ctrlv.cz/0Ok5 - and here’s video how it look’s like in system - https://youtu.be/EpWdWK_Lh6M . ( sorry for my english, i hope you can understand it )
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi there!
I would suggest the following:
  1. Disconnect/remove the display.
  2. Inspect the display ribbon cables for any pinches or tears and inspect the connections and contacts on the logic board for any damaged pins.
  3. Use a Q-tip dipped in Isopropyl/Rubbing Alcohol to clear out any debris in the connections and contacts.
  4. Re-secure the display connections and reseat the display.
  5. With the new screen installed, power off the device and let it sit untouched for at least 6 hours.
If this doesn’t help, it is possible that some sort of damage did happen during the repair or pins on the connections on the display or it could simply be a bad display. Hope you are able to figure it out though!
这个答案有帮助吗?
得分 1
添加一条评论
Probably just a bad LCD but you might be able to reseat the lcd ribbons. Most likely a screen replacement.
这个答案有帮助吗?
得分 0
添加一条评论
There is a chance that the new screen for the iPhone 6 was not replaced properly, and your friend might have done something to dislodge it accidentally.
It might be best to take the iPhone to a shop and have a technician replace the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
- Ungeros - 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 112
