跳转到主内容
修复你的物品
维修的权力
配件 & 工具
非一体化电脑称之为台式机。
1280 个问题 查看全部
Is this CPU compatible with my motherboard?
Hi, so I’m building a gaming PC and I am purchasing an AMD 2200G Quad Core CPU. I have heard that the motherboard would need to have a BIOS update to use this CPU. Will this CPU be compatible with a MSI B350M Pro VD Plus ''motherboard? Or will it be totally incompatible? I am fine with updating the BIOS as long as I don’t need the kit from AMD to do it.
Thanks in advance!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
Manta 螺丝刀工具包
日常维修的112个替换头
Upgrade Your Toolbox
Manta 螺丝刀工具包
2个回答
已选择的解决方案
Yes, your processor will be compatible, you should also be able to boot to the BIOS to update it as well, however, it may be unstable, just keep that in mind.
Also, wherever you are buying the motherboard from may be able to assist you with getting the BIOS updated before you receive it, I would send the company an email or phone them to ask if they would be able to assist
这个答案有帮助吗?
得分 1
评论:
Oops, I meant a B350 Tomahawk. Will it still be compatible?
完成的
It's actually compatible - regarding my Answer.
完成的
Great! Thanks!
完成的
添加一条评论
最有帮助的答案
Hi,
it is compatible, but if there will be some problem with drivers or “compatibility”, you must update your BIOS, because from manufactory, the MB is ready for 1st and 2nd generation of processors, but processor, which you are going to use, is 3rd generation.
So yes, it is compatible for about 90%
这个答案有帮助吗?
得分 1
评论:
So all I have to do is update the BIOS? Also, will the motherboard turn on in order for me to update it, or will I need the kit from AMD?
完成的
Yes, just update BIOS, I think, that you must enter to BIOS and you have 90% done, there may be Update Bios option, if not, you have to create USB Update, or use AMD Kit.
完成的
添加一条评论
添加你的答案
Random _User_101 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 65
