Kenmore 700 series does not spin when spin light is on
My Kenmore washer does not spin while the spin light is on. Everything else works just fine and it washes clothing but does not spin while on spin cycle. How do I fix this?
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
UPDATE
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
这个答案有帮助吗?
The lid locks and it stays locked so I don’t think it’s that.
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 35
总计 3,264
2条评论
Hi @dfoust ,
What is the full model number of the washer?
由 jayeff 完成的
Hey jayeff, the model number is
MOD 110. 28132410
由 Dfoust 完成的
