跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1623 个问题 查看全部
Can I replace 2.5 GHz Logic Board with 2.9 GHz Logic Board?
Hi,
Due to some misfortune, the logic board in my 13” MacBook Pro is damaged. Since the rest of the system is in perfect shape, I’d like to replace the board. I have a 2.5GHz board, can I replace it with a 2.9GHz board? All would still fit?
Thanks in advance.
With kind regards,
Sjoerd
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Yes! You can use a better version of the logic board that was used in your systems series.
Here’s the IFIXIT guide to take it out MacBook Pro 13" Unibody 2012末主板更换 and here’s the needed part from IFIXIT MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board
MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board图片
产品
$299.99
这个答案有帮助吗?
得分 2
2条评论:
Very fast again Dan, thanks a lot!
完成的
Happy to help!
完成的
添加一条评论
I did this and everything works except the display is black. I’ve used safe mode, disk utility, reset NVRAM, PRAM and tried to download Catalina(36hours - didn’t). Display is still black! Help!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sjoerd Herder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 172
