跳转到主内容
A multi-function laptop released in 2010 by Toshiba. Can be used for leisure, business, or education.
13 个问题 查看全部
My laptop won't switch on, why?
When I plug my charger in the light of caps lock flashes and the light showing it's charging is also on but pressing the power does not result in my laptop switching on. Does anyone have a clue what's the problem and how to sort it out?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try the following.
  • Remove the battery and press the power button for 30 seconds
  • With the battery removed, plug in the charging cable and check if you can boot
If that doesn’t work, your battery is dead.
这个答案有帮助吗?
得分 0
评论:
Didnt work. Battery probably is dead
完成的
You might be able to find a new battery if you search the partnumber of it on Google. Usually the partnumber is located on a sticker on the battery,
完成的
添加一条评论
添加你的答案
Hamza ahmad 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 52
