跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Can I fix my fried iPhone SE motherboard
I have a water damaged motherboard. I tried to clean it with isopropyl alcohol. Nothing changed. Will reballing fix this? If I move the memory parts to another board will that work? Any help to repair this board will be welcome. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Most repair shops treat water damage as data recovery only, because there are so many things that can go wrong with water damaged phones.
这个答案有帮助吗?
得分 2
5条评论:
So it will work if a move the data chips over to a new board?
完成的
As long as the chip wasn't damaged by the water, then, in theory, yes, but there's no guarantee.
完成的
How can I tell if the chip was damaged?
完成的
I don't know. I don't do board level repairs, so that would be up to the person doing the repair. Other than looking at it to see if there is corrosion, I wouldn't know how to test it or tell if it's working.
完成的
Thanks for the help
完成的
添加一条评论
添加你的答案
Isaac Goodwin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 116
