跳转到主内容
Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
112 个问题 查看全部
Why does the screen hang on my Samsung Galaxy Tab 7.0?
Sometimes my Galaxy Tab's screen will hang. I try to turn off, but it doesn't work. I bought it less than a week ago, but I'm already having problems with it. I charge it for only 3 hours at a time and make sure that it already has a drained battery before charging.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 80
29条评论
I cant understand you, please explain your problem more specifically ...
完成的
my tab is no opening,its needed to opengles2.0 need. so how to this problem solved,ples.answere
完成的
wow tx ur info helped my heart just stppd beating as soon as it hanged thank u again
完成的
my samsung galaxy tab 5 hangs, when i accidentally pressed the auto software update.. then it loads. when i am about to open it it froze, and never open.. please fix this as soon as possible.. :'( :( :'(
完成的
my tablet does not turn off i have the samsung tab 3 it froze and does not let me do any thing it stays with the same time and same charge it stays on my home screen what should i do?
完成的
显示更多的24条评论
添加一条评论
9个答案
已选择的解决方案
When your tablet hangs, just connect it to your computer or laptop with a USB cable and hold the power button. It will reboot automatically.
这个答案有帮助吗?
得分 42
37条评论:
Thank you very much. I was having the same problem and just did what you said and BAM!!!!!! it just rebooted. You guys are doing wonderfully well. Kudos!!
完成的
its worked ... great
完成的
it dont work on my tab. i already press and hold the off button with the volume up but still its not working. i also remive the sim on the side but still, ITS NOT WORKING. im starting to worry and im !#^&@@ off
完成的
oooooh my god just did that thank you so much it really helped a lot,now its working again#kudos for the strategy!!!.
完成的
Thank you friend. mine is also same problem i did it now there is no problem for galaxy tab 3 mini. Thank you soooooooo much.
完成的
显示更多的32条评论
添加一条评论
If the Tab hangs, press & hold down the Volume Up & Power On/Off buttons together, till the Tab shuts down...
这个答案有帮助吗?
得分 18
17条评论:
this works - also , dont load up too many active apps at once .
完成的
thank you so much it worked like a charm for me :)
完成的
Yes, that's it. Volume AND power!!! just wondering whether this is how you go with your tab - always laptop next to your tab to be able to fix problems...
完成的
Thanks .. it worked \^_^/
'da best
完成的
Sourabh Thank you so so much your a star
完成的
显示更多的12条评论
添加一条评论
CPress power button and volume down button at the same time. And hold for long time (30 sec for me). It will restart again. Good luck.
这个答案有帮助吗?
得分 5
5条评论:
thanks boss. your idea is worked out.
完成的
thank y so much!
完成的
thank you so much, it worked \^_^/
完成的
Thanks boss it worked for me too....
完成的
Worked bro. Thnx..
完成的
添加一条评论
if it is not working,then let it go and finish all of its charge so that it can close.then u put on charge and after it refills open tab and delete the app that made it and some other few for no other problems...
这个答案有帮助吗?
得分 2
添加一条评论
In case the Tablet is hung up and not responding to any command including shut off .
1. Please press and hold the shut off or power off button for a long (may be three to five minutes or more ) The tab shall shut off and now you can start it again This I tried on mine and was sucessful
这个答案有帮助吗?
得分 2
1条评论:
I had same problem with my tab 3 but what's the reason for it,I have free storage n latest updates in it it takes so much time to charge I m just tired doing this now
完成的
添加一条评论
if nothing work for you then
press power key + volume key
(Note: volume key not in upper or lower end but in centre)
tap both key once and then press both for long time
within 2 minutes tablate will restart
It worked for me.
Try once may be it will work for you too.
这个答案有帮助吗?
得分 1
2条评论:
thank you!!!!!!!!!!thank you!!!!!sooo much nothing worked but it worked
完成的
thank you so much, it worked for me.
完成的
添加一条评论
Tried everything suggested on my Tab 3 that was hanging at Samsung, fianlly long hold of power and up volume brought up menu that I finally did a sytem rest after trying all the other choices, it restoreed my Tab 3 to working.
这个答案有帮助吗?
得分 1
添加一条评论
Hy man ,my best answer is this that you should press power key for a long time,and then it may start,or else you should press volume and power key both for ten second after ten seconds release volume key and press power key for more ten second,i am sure it will work
这个答案有帮助吗?
得分 0
2条评论:
I did all these tips pressing both for long time and usb cable joint all but its not turning on pls help me
完成的
its amazing... thank you ,,, your idea worked!!!!
完成的
添加一条评论
connect samsung tab to the laptop or pc using ur data cable...... press volume down key and power key together for some minute.... around 1-2 mins....
this shud reboot ur tab and problem shud b solved...
这个答案有帮助吗?
得分 0
1条评论:
but it doesn't work
完成的
添加一条评论
添加你的答案
leiyamamoto20 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 15
总计 189,158
