My iPhone 6s replacement screen has 2 ribbons but the phone has 3 port
do I need all ports, the screen does not turn on after fitting the ribbons to the correct ports
That’s because the third flat cable doesn’t strictly belong to the screen assembly as it can be relatively easy swapped from the broken screen to the new one. That’s including the front camera, ear piece, proximity sensor and ambient light sensor. Here’s the guide for the replacement: iPhone 6s 前置摄像头与光线传感器组件更换
这个答案有帮助吗?
I realised this when working on the phone. I very much appreciate your comments . Thank you very much
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 583
2条评论
Do you have some pictures?
由 Nalin Loypetch 完成的
I have found my answer. The third ribbon is taken from the broken phone and put on the replacement screen.
Thank you for you response
由 Hisham Atcha 完成的
