跳转到主内容
My tv won’t turn/power on after being unplugged for a couple of hours
I moved my tv and then moved it back to put it back on and plugged the tv back in, no lights or anything came on when I plugged in back in. I have changed the fuse in the plug, the power cable and the socket.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
I had the same problem with our sony. later on we found out that it was a burned out screen bulb in the tv. We took ours for a tv trade in to get money off our new tv.
完成的
Hi @k12 ,
What is the model number of the TV?
完成的
添加一条评论
2个答案
最有帮助的答案
Hello,
If you had been check a all things means cable and power supply then you should talk to your customer service and talk to where you purchased it.
这个答案有帮助吗?
得分 1
添加一条评论
get it checked from some professional technician or if your product is under warranty, take it to the service center maybe some internal problem is causing this issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 851
