跳转到主内容
修复你的物品
维修的权力
配件 & 工具
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
5041 个问题 查看全部
Is this display connector broken?
Can anyone tell me if this display connector is looking good?
The display brightness is not working correctly. I use a cheap eBay replacement display so before I order a new one I want to know if this connector looks good.
The 6th pin on the top looks weird to me..
Thanks!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
Manta 螺丝刀工具包
日常维修的112个替换头
Upgrade Your Toolbox
Manta 螺丝刀工具包
2个回答
已选择的解决方案
For me, it's rather difficult to tell by just looking at this picture. Check carefully with tweezers if there is any unstable pins, which features poor contact with board.
It would be better if you have a multimeter to test the diode value of each pin on the connector. If it’s all normal value, then restart with a new display.
这个答案有帮助吗?
得分 1
评论:
Thanks! Will try to use tweezers and/or check with a multimeter.
完成的
添加一条评论
最有帮助的答案
Looks okay, might need to clean up the connector a bit on the 6 pin. 99% isopropyl alcohol and some brushing should get that cleaned.
Otherwise be extremely careful with tweezers / exacto knife to clean that out without damaging the pin.
这个答案有帮助吗?
得分 1
评论:
Thanks for your comment. I've tried cleaning it with IPA two times but that didn't work. I will try to remove it with a tweezer.
完成的
添加一条评论
添加你的答案
Matthijs 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 32
