跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
432 个问题 查看全部
Why is my display fainting, high brightness
This is what my display shows:
I’ve replaced the LCD, LVDS cable, LCD temp sensor.
I’ve also try plugging in an external monitor and it shows perfectly no signs of the faint image.
When I boot the system display it randomly shows a normal image sometimes but when it does, the system powers off or goes to sleep. I can hit the space bar to wake it up sometimes but once I restart the system, it goes back to the fainted screen.
Could it be the GPU still even though the external monitors shows perfect? Or the logic board? Power supply?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
5条评论
To be clear the external monitor also has the same faint image is that correct?
完成的
No the external monitor shows perfectly which is why I’m so puzzled
完成的
Is it left alone for a long time
完成的
Never mind it very old? Or needs a sweep in junk or caehe
完成的
Yes it’s early 2009 A1225. Maybe so, i May need to reinstall OS
完成的
添加一条评论
2个答案
已选择的解决方案
My bet would be a failing inverter or cable. There is no guide for replacing it the 24” but the on for the 20” should work just fine:
The Cable Inverter , power is Apple part #922-8856
There is a possibility the 24” does not have an inverter, you’ll have to look. In that case replace the inverter cable
iMac Intel 20" EMC 2133 and 2210 Inverter Replacement
Here the complete Apple Service Source on your machine:
http://tim.id.au/laptops/apple/imac/imac...
这个答案有帮助吗?
得分 3
2条评论:
Hey, thanks for the response. I've purchased the inverter cable and will be delivered Friday. I really think its the cable also because the A1225 model doesn't have a inverter, its on the LCD panel. The inverter cable is the only cable that hasn't been replaced that connect to the LCD so hopefully this will solve my issue.
完成的
Im with the 24" Mac with no inverter facing this problem , what i could do?
完成的
添加一条评论
I think you’re facing two issues which are interrelated.
First I would replace the PRAM battery which is located on the bottom right side of the logic board. Follow this guide to Step 12 iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement
Once replaced lets reset the display
  • Start by choosing Apple menu > System Preferences …
  • Select the Displays Preference Pane
  • Click the Color tab
As soon as you do the washed out screen should be gone.
这个答案有帮助吗?
得分 2
3条评论:
How do i reset the display?
完成的
The action I listed will do it auto-magically!
完成的
hey thanks for the response. new battery was delievered yesterday and installed it and it still shows the faint image so i will try the inverter cable now
完成的
添加一条评论
添加你的答案
Corey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 719
