跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Why my camera and flashlight doen't work?
After a drop, i replaced the screen and i noticed that back camera, front facing camera and flashlight don’t work anymore. But if i unplug the back camera the front faceng begin to work. Is it possible thah after the drop, back camera damaged and that issue conflict with working front camera?
Thank you so much and sorry form my bad english
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Yep, it is most likely that the rear camera is causing a short circuit which drains the power on the camera circuit causing both cameras, including the flash module to stop working.
Replacing the rear camera should fix the problem.
iPhone SE的后置摄像头更换
iPhone SE (1st Gen) Rear Camera
iPhone SE (1st Gen) Rear Camera图片
产品
$24.99
这个答案有帮助吗?
得分 1
1条评论:
Thank you very much, i’ll replace rear camera and i hope should be fine.
完成的
添加一条评论
Just ran across this. My iphone SE slipped out of my bag while riding a motorcycle at about 35 mph going to class. It landed in the middle of the street (double yellow lines) and sat there for about 4 hours in the hot sun before I noticed. The road wasn’t busy, but I know that two rigs pulling trailers past it 4 times (one I drove for CDL practice). Lucky it wasn’t flattened and still was functional after laying on the asphalt in 90 plus heat. The screen cracked, but that is expected. Besides the screen, I noticed neither camera or flashlight were working. I’m taking a chance and ordering the back camera and a cheap tool kit to see if this solves my issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emanuele Amantia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 455
