跳转到主内容
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 个问题 查看全部
Audiobooks download to iTunes, but won't sync to iPod Nano?
I purchased a book and downloaded to my iTunes menu. The book appears in the library, and in audiobooks but will not sync to my iPod device.
I have restored, reset original settings, started over, and still no sync. I can see the book in the library and in playlist/audiobooks so I know it downloaded.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
已选择的解决方案
Sorry but it seems the first Gen iPods are not compatible as they don't run OS4
Requires iPhone and iPod touch with iOS 4 or later. iBooks is not compatible with original iPhone or iPod touch (1st generation).
Refer THIS link for the details from Apple
Under the What are the requirements to use iBooks? iPod nano is not listed so I assume it is not compatible.
这个答案有帮助吗?
得分 1
添加一条评论
Year, this AudioBook Converter is my personal preference and what I'm most familiar with. It was a one-click install, very easy to put your iTunes audiobook to iPod.http://www.macsome.com/
这个答案有帮助吗?
得分 0
添加一条评论
If you are looking for a method to sync audio book to iPod, I think you should convert audio books to MP3 format at first. here is the best audio book converter for me. It can help you batch convert all your audio nook files from iTunes AAC files to MP3 losslessly, then you can transfer them to iPod successfully.
这个答案有帮助吗?
得分 0
添加一条评论
I am going to disagree with you slightly on high performing customwriting AudioBook Converter: there’s no need to convert to MP3 format at first.
这个答案有帮助吗?
得分 0
添加一条评论
As I know, iTunes audiobooks are only available for iPhone, iPad and iPod Touch. If you’d like to transfer iTunes audiobooks without the ability to installing apps, you can use an audiobook converter to help you convert iTunes audiobooks to MP3 first. Then there won’t be any problems.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maura 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 5,681
