跳转到主内容
This guide will enable you to be able to repair any issue with your PowerBeats3 Wireless Earphones
39 个问题 查看全部
I'm Having audio issues
The audio in the right side is lower than the left
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello, from what it sounds like, I believe your earphones are dirty with earwax and dirt. What I can recommend is taking an extra toothbrush you have and wetting it with a VERY SMALL amount of water (excess could damage them) and scrubbing the earpiece that the speaker is in (circled below) lightly with the wetted toothbrush. You could also use a toothpick and lightly scrape out any dirt or earwax. Be careful and hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph Whitfield 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 62
