跳转到主内容
机器可读指令,可以指导计算机处理器从互联网上下载和渲染“猫”的图像。
147 个问题 查看全部
Is there is any way to migrate Office 365 from GroupWise
How we can move from GroupWise to Office 365 without having any major issue such as data losses, is there is any method or tool which can easily migrate groupWise mailbox into office 365. Recently i try many free tools but non of them work properly. each mailbox size is around 2 GB approx. Please suggest best solution regarding this issue.
Thanks and Regards
Patrick
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 2
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
已选择的解决方案
If you want to Migrate from GroupWise to Office 365 then, you must try shoviv GroupWise to Office 365 migration software which is trusted and reliable software for every GroupWise user. Using this software you can easily migrate GroupWise mailbox as well as GroupWise archive into Office 365 without losing any data items. The software also exports GroupWise mailbox into Outlook in an accurate manner. You can also save GroupWise data into various formats such as PST, EML, and MSG.
To know more feature visit at: '''http://sites.google.com/view/groupwise-t...
这个答案有帮助吗?
按维修分数 0
评论:
Thank you for your suggestion
Welcome, Patrick, I hope the above solution helps you.
添加一条评论
添加你的答案
Patrick Roggers 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 52
