跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1695 个问题 查看全部
Disk drive not ejecting or receiving disks, will read though.
Hi guys!
Cleaned my 4yo PS4 the other day, but when I put it back together the disk drive isnt accepting or ejecting disks, it makes three quick beeps when pressing the eject button.
The only problem I had with the teardown was I broke the tabs on one of the ends of the ribbon cable going from the MB to the disks drive, but it's seated and the drive is reading this disks fine with manually put in.
Would that be the issue or have a missed something else?
Thanks in advanced!
Update (02/11/2019)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hello sir and good day,
try this remedy and let let me know:
The first step is to hold down the power button until the system beeps twice. Then wait about 30 seconds until all system lights are off, unplug the power cable, and leave it be for three minutes.
let me know if it works
这个答案有帮助吗?
得分 0
5条评论:
Hi Daniel,
This has not worked unfortunately, what do you sugest next?
完成的
Have you confirmed the cables going from the motherboard to the optical drive are inserted properly and fully?
完成的
Can you also upload images of the tabs you broke off also
完成的
I have added photos into the original question
完成的
Replace the ribbon cable as that most likely is culprit . I would start there as it’s a cheap replacement and see if that’ll fix the issue
完成的
添加一条评论
添加你的答案
Stewart Mckenzie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 49
