跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
Ipad Air 2 motherboard battery pins
Hi all
Need advice as to whether it is possible to have the battery pin connector part replaced on the motherboard as I stupidly broke one of the pins off that help power the ipad on when separating the board from the battery (see pictures)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
The broken pin is BATT_SWI_CONN and it is used to communicate the battery charge state to the CPU. The actual connector is soldered on to the logic board so the only way to fix it is to replace the connector or solder a bridge from the battery directly to the end point on the logic board. Neither of these options is a DIY repair unless you are skilled in micro-soldering.
这个答案有帮助吗?
得分 3
4条评论:
As you can see in the picture there is a small piece of the connector/prong showing, so could I not just add a bit of solder to it so at least it will connect to the battery connector pads
完成的
You could try...Keep in mind that you are working on the logic board so any problems you create could damage or kill the board.
完成的
Can someone please explain purpose of all these pins. What each pin does. Does iPad Air 2 uses all of these pins for some purpose?
what goes wrong if any of these pins break?
please help.
完成的
“Can someone please explain purpose of all these pins. What each pin does. Does iPad Air 2 uses all of these pins for some purpose?
what goes wrong if any of these pins break?”
I would like to know this as well.
完成的
添加一条评论
添加你的答案
colin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 1,332
