跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance.
60 个问题 查看全部
How to replace the sd card cover on nikon d3200 camera
The exterior door/cover for the SD card slot broke. I can obtain a replacement door, but do not know how to replace it. Any resources?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
Not sure how close the screws will be to that panel, might want to look at the replacement part for where it has screw holes!
I took that part off while doing other work, on my D500, and although it showed 2 screws, there were 4 more hiding under 2 pieces of rubber! May need to peel the rubber up around the door to find them.
Nikon D500 Memory Card Cover Disassembly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim Keller 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 5
总计 23
