跳转到主内容
A home audio speaker for iPod by Bowers and Wilkins introduced in 2007.
25 个问题 查看全部
B&W A7 AirPlay audio board repair?
My B&W AirPlay a7 was working fine until the day it called it quits.
Now I am having a red blinking led.
After the teardown of the device the dsp board has a burned area under the thermal compound.
What I need to ask is if there is a complete dsp board as a spare part or what is the number of this part.
Any help would be appreciated.
Thaks for listening.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi Anthony
Although your post is of some time ago ...
I am just working on my 2nd B&W A7 repair. This one seems to have the same issue as yours. I also noticed burn marks in the white thermal pad that touches to the bottom side of the Amplifier PCB. See picture:
However, when I look at the section of the Amplifier PCB that touches the thermal pad, I cannot see any burned/damaged component. See picture:
You have the damage between Mosfet's Q15 and Q20. My burn marks are between Mosfet Q25 and Q30.
Where are you now with the repair?
Have you been able to solve it?
My questions
Does anyone:
  1. Know what component L38 is? (type/values)
  2. Have a list of all components of the A7?
  3. Have the electronics schematics?
这个答案有帮助吗?
得分 0
2条评论:
bought a used A7 with psu damage and i replace the audio board.
it is working fine now for more than a year.
完成的
Thanks for responding Anthony.
Are you into the electronics of these products/capable of repair on component level?
完成的
添加一条评论
添加你的答案
Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 15
总计 191
