跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Why is the battery only charging halfway?
I have replaced the LCD degitizer screen with new and after that power button does not work anymore and only charging halfway and also quickly drains power. Can someone help whats wrong?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
May be unsecured cable connections?
完成的
添加一条评论
1个答案
The power button failure MIGHT be the result of a bad connection to the motherboard. The connector in question is here:
https://d3nevzfk7ii3be.cloudfront.net/ig...
However, given your power button issue + the lack of full charging + fast power drain (+ excessive heat, which I'd bet your phone is also showing), I'd put my money on a failure of the Tristar (U2) charging chip, which requires microsoldering skills to repair. Even if the power button failure is not the result of the Tristar chip, the rest most certainly is.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eiji Uehara 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 508
