跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
Why can't my iPhone connect to any wifi networks?
I have an iphone 3GS. I don't use it with a phone plan; I was really just using it for the wifi apps. One day the wifi stopped working. It recognizes the wifi network but won't login anymore, not even to open networks including my own. I have reset everything, and erased everything including my own. I have reset everything, and erased everything several times. I bought a new sync cable and tried syncing it again. Still no luck.
My phone is not jailbroken and I have been hesitant to do that. Some forums have talked about it possibly being a problem with one of the updates in the software itself but I really don't understand how to go back to an older version of the software. My phone is not underwarranty.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Try these:
1. Go to General > Settings > Reset and press on Reset network settings.
2. Try to connect to some other Wifi network (Friend, coffee shop etc)
3. Try to disconnect your router and connect.
If non of them is working:
*then try restore via iTunes to the latest 4.3.3 Firmware.
*If restore doesn't work, then maybe the WIFI cable got disconnected from the board :/
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Emily 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 41,642
