跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1696 个问题 查看全部
Optical drive no power
Hello, I fixed the optical drive roller which was misplaced to fix the CD intake problem, This problem was fixed but I was still getting error with disk reading so I decided to replace the laser kit. I successfully replaced it. I restarted my PS4 but no activity in optical drive. It is not doing anything. Seems there is no power. It seems something got wrong during re-assembly. Not sure how to fix now. Any suggestion and how to check if optical drive is getting power. did any cable got bad?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
maybe you nicked a cable going to the drive , or its a software issue
这个答案有帮助吗?
得分 0
添加一条评论
Most laser assemblies ship with a shorting solder connection on the ribbon cable to prevent static damage. Look carefully at the cable on the optics assembly itself for a small “bubble” of solder. Remove this and the laser should work. Since the assembly won’t attempt to spin the disk unless one is detected (laser lights and detects the reflection if a disk is there), it may appear that the assembly has no power. Check for the short and update this with what you find. If you can, post a few pix of the assembly from different angles too.
Dan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lucknow_99 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 65
