跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
259 个问题 查看全部
A1707 - Blacklight Flicker
Hi,
Just picked up a 2nd User 15” MacBook Pro with Touch Bar (A1707).
I’ve just noticed it sometime seem to go though a state of the blacklight flickering for a minute of so. More when I’m moving the Device (carrying) however if I change the brightness it will flicker for a second. Its not all the time. Just the odd now and then.
Anything I should be worried about?
Update (02/01/2019)
Additionally. I’ve turned off Auto Adjust Brightness and that seem to have stopped the issue. If that help? Is it a know problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Does tapping on the lid make it happen? Is the angle of the lid effect it as well?
完成的
添加一条评论
1个答案
最有帮助的答案
Does the whole backlight flicker or do certain areas such as the bottom flicker?
这个答案有帮助吗?
得分 1
5条评论:
The whole screen.
完成的
I read an article a few days ago about a possible hardware issue with the newer macbook pro's that causes this, because of the way the cable for the video and backlight is bent. It's been dubbed "flex gate".
https://venturebeat.com/2019/01/22/apple...
完成的
Hi. Sorry for the late reply. The whole screen flickers and after a bit of testing it's is something to do with the "Automatic Backlight Adjustment" turn that off and the problem seems to go away. With it on, if you move it just seems to be quickly/rapidly adjust the backlight.
完成的
Ah, ok. There is a cable that controls that I believe and it's an easy repair. Let me see if I can find more info about that.
完成的
添加一条评论
添加你的答案
Andy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 556
