跳转到主内容
Released May of 2014. The Motorola Moto E is also known as the Motorola XT1022.
35 个问题 查看全部
charging cord will fall out
When I place the charging cord in it will not lock in the port.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Have you tried using a different cable? It sounds like the small clips that hold the cable in place may be damaged.
这个答案有帮助吗?
得分 0
添加一条评论
Charging ports experience a lot of traffic in plugging and unplugging. Most likely in this situation the charging port has become “worn out” in that the connection may have experienced some slight bending or rather become “warped” and now can no longer hold the cord in place properly. The best fix for this would be to replace the charging port and the connection will be as it should. However in some cases the repair cost can outweigh the cost of getting a new device. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thomas Eaton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 38
