跳转到主内容
MacBook Air won’t turn on but charges
My girlfriends macbook broke and the 3rd party apple techs said it was the mother board. I did some investigation myself and saw no power coming in through the charger, so I bought a part online and replaced it. So far so good. It wouldn’t even light the charger up before, and now the charger lights up green then orange like it should. The first time I did it, the Macbook immediately turned on and I heard the boot up music. Now it won’t turn on. It’s still charging.
What can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
What was the part you replaced?
Disconnect the battery, press and hold the power button, plug the MagSafe charger back in are you able to get to start up?
完成的
添加一条评论
1个答案
Here is the Solution you can try
When you do not use it for long time it is possible it may not boot. Try this
Open Air back panel—-> Disconnect Battery for 2 mins— > Try to turn on using power cord—>If gets turned on use it for 5 mins —->Then turned off and Connect the battery and try..
Let me know if it works
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Owen Bick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 194
