跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
263 个问题 查看全部
Phone has no touch after screen replacement IOS12
We did a screen replacement on a iPhone 8 plus, and now it does not have any touch. It is running on IOS 12 and we have tried multiple screen replacements with the same issue. Checked out the board nothing is bent and everything looks as normal as it should. Anyone else heard of this issue?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
已选择的解决方案
Are you using an OEM/Original/Premium screen for the replacement? If so, keep on reading…
The 7/8 series screens are made by several manufacturers (Toshiba, LG, Sharp) and each phone is calibrated to the screen it has installed. It’s important not to mix and match screens. So for example, if your phone has an LG screen, you should replace it with an LG screen. The only way to know this is to look at the code on the backlight panel. Check out this blog (not affiliated) to learn more. However, even though you have a screen with the same code, it may still be a franken-screen. Lots of refurbish shops mix and match an LCD from one vendor, a touchscreen from another and possibly a backlight from another still. All you can identify is the backlight. This issue seems to be more prevalent on the Plus devices.
When replacing original quality screens, you should be using an ALS programmer to copy over the data from the original screen to the replacement screen. While this is primarily for the ALS sensor, it also helps with the Touch.
Curiously enough, the aftermarket screens don’t suffer from this issue at all. Unfortunately, they tend to have bland colours. A good alternative is an in-cell technology screen. They don’t have the touch issues and have great colours and are less expensive than OEM screens.
这个答案有帮助吗?
得分 2
评论:
it is a oem screen, but is it weird that with a screen that used to work does not work anymore? The phone was never dropped, phone was turned off before tear down an no resistors or anything was removed or pulled
完成的
I had a similiar issue. I installed the screen, tested and worked fine. the customer came back a few days later and it had a mind of it's own. Tried multiple "premium" screens and when left on for a few days, all had the same issue. Only the in-cell screen (or aftermarket) solved the issue. Even the ALS programmer did not help.
完成的
添加一条评论
Maybe you bent the digitizer pin when you replaced the screen but when this hapened you have to buy new logic board. This was best I find iPhone 8 Plus Bare Logic Board
iPhone 8 Plus Bare Logic Board图片
产品
$14.99
这个答案有帮助吗?
得分 0
评论:
Well thats the thing, checked it with no issues to any of the pins
完成的
It can be Touch IC chips being loose.Do you droped it before you replaced the screen #TouchDisease
完成的
There is no Touch Disease on the 6S/7/8 series of devices. That only applied to the 6P and to a lesser extent the 6.
完成的
Just Kidding Around XD
完成的
添加一条评论
添加你的答案
Alex Badgett 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 10
过去的30天: 59
总计 281
