跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Hewlett-Packard于1993年开始制造个人笔记本电脑。
1915 个问题 查看全部
How to fix snapped metal on the corner
I dropped my HP Envy x360 15 and the metal on the corners has snapped. What steps should I take to repair this?
Due to the snap, the HDMI port is inaccessible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
If it was me, I would just cut that piece off. From what I can see in the picture it does not look like it would hurt anything to cut it. Other than that you may have to replace that whole part of the of the laptop which would mean changing everything Mother board and all over to the new one.
这个答案有帮助吗?
得分 0
评论:
I added a second photo that shows the metal is bent out of place.
完成的
Ok it looks like you can just replace the keyboard top cover to fix the issue. I found one on ebay https://www.ebay.com/p/HP-Envy-X360-15-b...
Its not really that hard to do. You may look around and may be able to find one cheaper.
完成的
添加一条评论
添加你的答案
Torch Atlas 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 36
