跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2443 个问题 查看全部
iPhone 4 Randomly Turns Off After 18 Seconds And Reboots
Hello,
I Recently Got An iPhone 4 Online For $17 And Never Had Any Issues With It Until The iPhone Started To Randomly Reboot Every 18 Seconds And Has Lines When It Turns Off I’m Thinking This Is Some Battery Issue But The Device Does Recognize That It’s Being Charged But Never Goes Over 4% Of Battery I also Removed The Battery And Threw It Out Because I did not want the battery to break the phone or any leaking to happen but when i plugged the phone into a 12W iPad Charger But It Will Turn On For 30 Seconds And Gets Darker And Turns Off This It Could Have Been Some Liquid But The Water Indicator Was White
Why Does It Do This?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
Seems like a battery issue. The battery performance has decreased, due to its age, so much it cant even boot the phone. A good battery for a iPhone 4 is roughly $15-$30
As for the screen getting darker. That can be a multitude of things. The most common thing i have found to cause that is either the battery or a bad screen.
这个答案有帮助吗?
得分 1
评论:
But This Battery Wear Level Was Like 10%
完成的
I Ordered Another Brand New Battery So When My Battery Arrives I'll Report Back To You
完成的
Also, make sure you're using apple OEM cables. There are two chips inside Apple cables that are necessary for "a good charge" One is a chip that holds information saying "its an Apple device". Chinese replicas have been able to copy this, but the other chip needed is a voltage regulator, which is not found in aftermarket cables.
完成的
添加一条评论
添加你的答案
ryoseo1020 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 48
