跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
I'm scared to turn on my iPhone
I dropped my phone in my bathtub earlier and I got scared. I opened it up and used the cool setting on my hairdryer to dry the phone and its hardware and everything. I put it all back together and Now the screen wont go all the way in and I’m scared That i’ve accidentally punctured my battery. Its all in place but I’m scared to turn my phone on. Should I turn it on or not? what would you recommend?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello,
I am understand that your feeling so don’t be panic just clean your phone internally means If your handset has a resemble battery, similarly your phone has some kind of port cover or even a removal back panel, open it up to let your handset air out,
Don not dry your phone with a blow drier because the heat from the drier could damage your handset internally components permanently.
After the clean out your device cleaner (liquid) after that on the phone and check it. But you will be this work quickly,
这个答案有帮助吗?
得分 0
添加一条评论
Hi Vidhi,
I can totally sympathize with you here - a punctured lithium ion battery is no joke but signs of swelling are pretty easy to spot
Seating the display bezel in the phone body does require a bit of extra force for it to click into place and for the display to be seated correctly.
Once you’ve given the battery another inspection, try turning the phone on. If the battery is expanding, you’ll be able to see the pressure marks plainly on the LCD. You need to turn the phone on to assess what other damage may have occurred and determine if you are able to repair it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vidhi Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 55
