Is there a free tool to recover data from broken samsung galaxy s9?
How can I recover data from Samsung galaxy S9 with broken screen?
Yes, it is called adb and it comes with the the android SDK from google. Sadly it requires a couple of your phones internal software switches to be set in order to access your phone via the USB interface. If you have not already set these switches before the screen got broken you may be out of luck. Most phones now have cloud backup as a builtin feature. Again though, if you did not avail yourself of the builtin backup prior to this breakage, this won’t help you either. Also there are several windows PC softwares that claim to be able to do the backups to a PC without using the ADB route. Disclaimer… I have never tried one of these. Here is an example…
https://www.fonepaw.com/recovery/retriev...
I suspect these softwares are not free and I have no experience using them so I would be careful and check out whatever you go with thoroughly before spending money on such software.
这个答案有帮助吗?
To recover data from Samsung galaxy S9 with broken screen, maybe you can try broken samsung data recovery tool. With its help, you can easily access data on Samsung galaxy S9 with broken screen and get them back. Of course, if the data were deleted or lost, there is no way to get them back.
这个答案有帮助吗?
You can use Samsung recovery tool to recover data from Samsung galaxy S9 with broken screen. Restoring data from broken Samsung as well as other Android phones is possible and easy as long as you do not write new data on it. There are many free tool can do that.
这个答案有帮助吗?
Samsung Data Recovery is professional tool designed to help user recover data from Samsung,even the screen is broken.It has been recommend by many user,hope it can solve your problem.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 36
总计 7,056
