跳转到主内容
修复你的物品
维修的权力
商店
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1063 个问题 查看全部
*help* problems after repair
So, I was restoring an iPhone 7 Plus. I replaced the Chassis, LCD and Battery.
I transferred literally everything over from the old chassis to the new one, same with the LCD. I come to power on the device and I’m hit with a bootloop. After about 5 minutes of boot looping, it turns on BUT it says Searching at the top and my battery is showing 1% (on the new and old battery, I’ve tested both). It is not charging at all and whenever I turn it off, it goes back to boot looping.
I’ve tried the old lcd and battery but no luck there. The front camera flex is fully connected, I even tried when it was disconnected! What is happening?!
Bearing in mind, the phone was fully functional before I started this repair.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
3个回答
已选择的解决方案
Hi,
Are you using the original charging port?
A lot of times the replacement chassis come with charging port connection issues, this will cause no service issues and also cause the boot loop your describing.
If you transferred over the old port you need to go back and check it for any tears.
这个答案有帮助吗?
得分 1
评论:
Hi,
I transferred everything, including the original charging port. Is it most probably the charging port though? If so, I shall order a replacement one.
完成的
Hi,
I would order a new charger port flex. I think that would fix all the issues your experiencing.
完成的
Okay, I will update you when I’ve replaced it. Cheers!
完成的
This worked a treat! Thank you very much.
完成的
Hi, happy I could help, it’s always worth trying the basics before we go down the micro soldering route. That’s the way I work in my workshop anyway.
完成的
添加一条评论
sounds to me like the baseband cpu is shorted. if thats the case theres no way to fix it.
这个答案有帮助吗?
得分 0
评论:
Would it be worth trying a new sub pba though?
完成的
添加一条评论
Hi Liam,
as we all (microsoldering cominity) know that
iphone 7/7 plus board have diseases same as we faced back in IPhone 6/6 plus touch deseas and baseband deseas.
and this happenes because of stretch/shock or any kind of compact.
and if you search iPhone 7 rear down on Ifixit.
you ll find out the baseband and audio ic on iPhone 7/7 on opponent side of the board but at the same place.
now boot loop on iPhone 7/7plus is either home button or audio ic. If your home button is ok than it’s look like audio ic and baseband which make more sense as they are at the same spot of the board. To check go to dialling pad and press *#06# if you dobf get imei the basebNd needs rebelling and it’s repairable. To find out audio ic go to recording and try to record something if it says faild or no audio found error it means audio ic needs jumpers with audio replacement this is repairable too.
Not easy but possible.
i am saying this because that’s what I do everyday.
这个答案有帮助吗?
得分 0
评论:
I’ve just tried *#06* and nothing happens. Definitely the baseband IC then? Also the is no audio coming from videos.
完成的
So as I have explained in my comment. Baseband amd audio both needs sorting in you iPhone. bootloop is caused by audio ic and no service is caused by baseband. Before asking for repair you need to check whether it’s Qualcomm board or intel board?
And it’s happened because of may be the old housing was stretch/bent or you might have bent the board while replaceing the housing.
完成的
添加一条评论
添加你的答案
liam.jk1 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 147
