跳转到主内容
A1418/EMC3069/2017/3.0GHz四核心Intel Core i5、3.4GHz四核心Intel Core i5或3.6GHz四核心Intel Core i7处理器。于2017年6月8日发布。
154 个问题 查看全部
Single RAM slot upgrade
How does the memory bus look like in the 21,5” iMac? It has got two slots. Can I upgrade those individually or do they have to be in pairs. My guestimate of course is, that they have to pair up, but what are the facts?
Reasoning behind the question: one 16Gb stick is same price as two 8Gb and would add up to 20Gb when one 4Gb stick would stay in the mac. Also at a later point I could upgrade it to 32Gb, by buying one additional 16Gb.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Yes your machine will take one 8 and one 16 GB stick. However, after you look at the difficulty involved in installation (you have to pull the logic board), you may want to wait until you can afford to do the full upgrade 32GB at one time.
iMac Intel 21.5" Retina 4K Display (2017) RAM Replacement
这个答案有帮助吗?
得分 3
添加一条评论
One stick would work fine. I would only do so if you plan adding another one later as dual channel memory allows faster and better performance as the loads are split, rather than one stick doing all the work.
这个答案有帮助吗?
得分 1
4条评论:
So that would mean that I would half the bandwidth with just one slot? But then if it is dual channel split across those two slots, then the configuration with one 16Gb plus one 4Gb wouldn't work, correct?
完成的
@gekart
No, no. You could do 16 and 4.
Go ahead if you want, then later upgrade. Just seems funky. Just make sure it's for your mac :)
I kind of previously thought you wanted to do one stick.
The speeds would the same eitherway, not split. One stick or not. You kind of misunderstood.
It just eases the work load and can make it run better in some instances. And if one stick fails at least the other works.
Imagine one strong person carrying wood and loading but instead two people with less strength individually but add up to the same as that one person. One carrying wood and one loading.
So if you want clarification, you could go for it.
完成的
You lose interleaving with two different RAM sizes
@justbelikebrett The reason there are a lot of Mac question on this site is because it was built and is hosted by a company that started out as a Mac parts supplier and still is.
完成的
Using two different ram sizes can work and be fine as long as its the same speed, slot size and voltage.
You may be downsized to single channel memory speed like that but would work until he replaced it.
And nice to know mayer. I still think Mac users have more questions as its so limited, and annoying to do what you want on it. Specifically upgrades, replacements and OS fixes.
Apple loves it their way haha.
完成的
添加一条评论
添加你的答案
G E 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 13
总计 1,135
