跳转到主内容
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
24 个问题 查看全部
1005HA LVDS cable: Is 14G2235HA10 equal to 1422-00ML000?
Hi.
Looking for a replacement LVDS display cable for my EEE PC 1005HA. It takes a 14G2235HA10, and I've seen some vendors advertise a cable labeled with both this number and 1422-00ML000. Other vendors use just one or the other of these numbers.
Anyone know whether the 14G2235HA10 and the 1422-00ML000 are exactly the same cable with the same connectors?
The ASUS support site lists only the former number (http://support.asus.com/Search/KDetail.a...).
Thanks for your help.
--Frank
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
My research suggests that the cable is the same but it is based on the information supplied by various vendors I have found on the internet - much like you have. I'd stick to the primary number on the faulty cable and/or the number provided by ASUS
Update
Thanks much, Richdave! I took a chance and am happy to be able to answer this question affirmatively: the 14G2235HA10 IS apparently equivalent to the 1422-00ML000 cable.
这个答案有帮助吗?
得分 4
添加一条评论
yes, they are compatible lcd cable
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Frank DeSanto 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 3,226
