跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone SE screen glitch & restart
I recently bought an iPhone SE with a dead battery. I replaced the battery, booted it up, and it works great! However after awhile I came upon the issue of the screen randomly glitching out (pic attached) and eventually restarting. It will repeat this sometimes multiple times while trying to restart. It’s most easily replicated when put under load.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
I had a similar problem. After investigating under Microscope I found out that one of the capacitors on the PCB board are loose. I have re soldered and problem fixed! :)
这个答案有帮助吗?
得分 1
添加一条评论
Hi James,
I would first check the display connectors, disconnecting them, making sure there are no particulates on the connectors, and reseating them. I would also check on the screw tightness of the logic board screws in step 17 of this guide:
iPhone SE的逻辑板更换
这个答案有帮助吗?
得分 0
1条评论:
I also have this problem and that glitch Killed my iPhone and it won't activate
完成的
添加一条评论
添加你的答案
James Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,017
